Firstly as I said the discussion is whether torque = work.In which case it’s anyone’s guess as to what difference your ideas make to that.
Not with me the discussion wasn’t. I think you’re confusing your conversation with Roymondo.
Below is the post where you tried to ■■■■ heads with me over something I was having a perfectly reasonable chat with someone else to do with that torque/RPM equation:-
Freightdog:
Not exactly true if you look at the maths. Torque is variable with rpm, it’s value is not independent of rpm (speed) at a fixed power (HP)
And your challenge:-
Torque is independent of rpm.
See. Nowhere did I discuss with you this ramble you about torque=power. I was discussing the relationship between Torque and rpm based off a particular equation, quite civily with someone else when you piped up and stated Torque is independent of RPM.
Given the equation that was being referred to, your statement still is a bit odd as its right in front of you. Anyway
Not content with this boo boo, you trumped that one further by blurting out some incorrect sloppy maths in an attempt to patronise after I had questioned how you could make such a statement regarding Torque and RPM when looking at the equation. You kind of asked for it really.
Moving on.
As for arguing with the premise/fact that power = torque x engine speed which is just ‘corrected’ by the ‘constant’ 5252 I’d suggest that you’re in a hole stop digging.
Mm, no. I’m quite sure who is in a hole. If you’d said something like “part of the equation is the product of X and Y” then fair enough. But you didnt, you tried to patronise me and dismiss it, having waded in, so sorry. If you’re going to make vague mathematical wordy statements, at least make the whole thing correct.
If I were to dismiss a type rating examiner by saying " the MAC percentage is simply the the station times the moment, that’s a given" I can tell you, I’d be debriefed on an incorrect statement to make sure I knew the fundamental, as any discussion leading on from there relies on stating the whole thing. Maths equations aren’t concepts. They need the whole thing to be correct, especially when completing performance and engine thrust calcs.
If I further more attempted to squirrel my way out by dissmissing the examiner as being in hole and digging as I didnt mention the constant as its “only a correction” , well…good job, you’re not facing a German TRE any time soon. I think it quite possible you’d manage to single handedly restart the second world war. That or make a grown man cry.
