LHD Foden 4000-series
There are some fascinating shots with info posted by ‘Leyland Ash’ on page 22 of the Fodens thread this week. Here’s the link:
viewtopic.php?f=35&t=130552&start=630
Robert
This was taken at the Foden factory. I think it was for export and has the fuel tanks behind the rear wheels.
French-reg Foden probably attached to the Faversham depot at Oare. Can anyone remember which gearbox these had? Robert
Been informed by kmills on the Kent thread that these ^^^^ had Eaton Twin-splitters in :wink: . Robert
can t believe theres no photos of bromilows fodens there were popular moters doing europe every week
rft int:
Good man! I had no idea Bromilow had LHD Fodens, let alone 4000-series until I saw your post. I’ve just Google them and immediately came up with a picture of one :sunglasses: . Cheers, Robert
ERF-NGC-European:
rft int:
Isn"t that the model before, S108?
colinwallace1:
ERF-NGC-European:
rft int:
Yes you’re right Colin - I should know really because I drove one! That’s the Mark 4 version of the S10 cab so it’ll be an S106 on three axles.lol Robert
ERF-NGC-European:
colinwallace1:
ERF-NGC-European:
rft int:
Yes you’re right Colin - I should know really because I drove one! That’s the Mark 4 version of the S10 cab so it’ll be an S106 on three axles.lol It probably had a 9-sp Fuller in it then, like the RHD one I drove. Robert
Blimey, RFT INT has started something off here! I didn’t know there were any LHD versions of those earlier S10 Fodens. Anyone know for sure what engine/gearbox that Bromilow unit had? Robert
ERF-NGC-European:
I recall seeing one parked up on a motorway lay by, close to my home here in the Netherlands? Way back in the nineties a rare sight. A bright yellow three axle Fodens of an older type . Curtains closed. Driver sleeping I walked around it. I recall it was Cat powered, but I’m not sure.
Regards
Rolf
Verstuurd vanaf mijn SM-T335 met Tapatalk
rolfkerkhof:
ERF-NGC-European:
Regards
Rolf
A lot of the left-hookers seem to be CAT-powered, Federici’s Fodens among them :wink: . Robert
I’ve found more evidence of LHD Foden S106 units in Wobbe Reitsma’s book on export Fodens. Apparently, from 1986 onwards quite a lot of them were exported to Israel with CAT engines. No mention of what gearbox though. Pic below. Robert
And here’s another Israel export LHD Foden S106, this time with a ■■■■■■■ NTE 400 lump, split windscreen and double-drive. Still no gearbox clues though. Perhaps ‘Leyland-Ash’ can help us with that one! Robert
Looks better up this way chap ! :laughing: :laughing: :wink:
DEANB:
:sunglasses: Thanks!! :laughing:
The one I drove had the 3406 Cat, 13 speed R/R, and Dana axles on rubber suspension. Colin.
(Rhd S106)
sorry i cant be of more help i alway remember seeing them in Geoff s yard when i was passing were Gavin mc ardle these day s he d know
DEANB:
I wonder why that bottom one has the cab set up so high.Would suggest the fitting of a larger engine.
Soma or atlantic engineering hub reductions too?
railstaff:
It’s quite a bit different from the norm. The step panel is deeper, plus the cab is mounted further above the lamps. It’s on 24" wheels too, if I’m not mistaken.
