Leyland Buffalo
ramone:
ramone:
The TL was more than a match for like for like engines ie same power output . The Daf i see is now thrown into the equation , if you pitch a 280 Daf then they are comparable , put a F10 in there they too are around the same output but you don’t seem to be able to do that. Put the Daf and Volvo against say a 480 turbostar and tell me how they compare . Well they dont because ir’s a different catogary.
Put the unreliable Rolls 220 against the AV760 with similar power . Put the 205 ■■■■■■■ against the L12 i dont think the 205 was still being produced when the L12 was launched. Put the 201 Gardner against the L12 . Hell it’s not rocket science … maybe it is to some !
You want to ignore the DAF DKS because your 12.5 litre motor can’t match it. Same with the TD120.Then people moan about the Brits burying their heads in the sand regarding the foreign competition.
You compare engines on their capacity and their specific output.In the case of truck engines if your competition has an engine of equivalent, let alone less, capacity that puts out more torque than your best shot then you’ve got a problem.A big problem in Leyland’s case because it didn’t have the cash or the inclination to fix it.
As for the ‘unreliable’ Rolls.A supposedly inherently unreliable 12.1 litre motor that, unlike the TL12, went on to give a ‘reliable’ 1,200 + lb/ft torque and 350-400 hp from almost 1/2 a litre less.
So what if your requirements were for an engine up to 280 bhp , and when the TL was launched and up to it being discontinued 280 was firstly regarded as a high powered engine and at the end '81 levelling out to be the average output for the British market .Was it the engine that was highly regarded’s fault BL didn’t have the cash to develop it . I think not. As for the Daf it was nothing spectacular at 280 absolutely dreadful at 310 because i drove both . The 350 was a good motor but the 360 Turbostars were just as good if not better
It would be fair to say that DAF wouldn’t be where it is today if it hadn’t have been for the success of the DK motor.Bearing in mind you’re comparing 11.6 v 12.5 litre in this case.
While the TD120 and Rolls 305 and ■■■■■■■ 335 and DAF DK all showed which way the wind was blowing and a design limited to 280 from that point wasn’t going to cut it.
As for 280 being enough in 1981 remind us when was the TL12 was dropped from the Roadtrain also bearing in mind a 320 option from at least 1983.
As for the L12 less specific torque and power output than a Gardner 180 says it all.
ramone:
ramone:
You aren’t making sense you keep going off at tangents bringing in engines that you dont need to
The L12 was an offering purely for the cheap low powered lorry that the Oil Companies desired, it also went in some other chassis for the same reasons, it was a Guy for the 1980s, a lorry that was meant to go from point A to point B and nothing else. As long as it met the HP/ton standards for 32ton nobody involved in the design, build or purchase of such a lorry gave a toss about anything else, there had been a significant demand for such a lorry for many years, in the case of Gardner powered versions people were prepared to pay a premium for a lorry that couldn’t pull the skin off a rice pudding, so why not pull the turbo off of an engine you already have the production line set up for and fulfil that desire with zero investment?
Also the TL12, was it designed or marketed to be a rival for a 2800 Daf or a Volvo F12? The answers are no and no, so what the hell have they got to do with anything?
newmercman:
Because while Gardner might just about have got away with fooling some of the people with the Gardner 6 lxb/c formula at the 10.45 litre mark.Others would have been asking the question why do we need this bleedin great big 12.5 litre L12 motor when we can get a Foden or a Scammell Routeman etc with a Rolls 220 or a Leyland 680 in it to do the job better and probably cheaper.
If the TL12 wasn’t intended to compete within the DAF DK or Volvo TD120 bracket then what else could anyone possibly need a 12.5 litre turbocharged motor for.
So you’re saying that using a 12.5 litre motor to compete at best with just the TD100 was a sustainable business plan for Leyland’s defence against the import onslaught. :confused:
What could possibly go wrong.Oh it did from at least the point, if not before, when Leyland finally decided to ditch it in the Roadtrain in favour of Rolls and ■■■■■■■ less than 10 years after its introduction with the need for 320 hp being identified within that time period.
The conspiracy being the question why did the government not make a hostile takeover of Rolls Royce over Vickers and then turn down DAF’s advances.Thereby providing Leyland with a competetive in house engine while also keeping its doors open. :bulb:
newmercman:
That’s what i was trying to say but i couldn’t put it across as well , i was talking instead of listening at school .
I was stareing out the window looking at the lorries driving past.
newmercman:
Not many L12 powered Buffalos, or TL12 powered Marathons from memory, but plenty of 590 and a few 690 powered buses and enough Scammell Routeman tippers and tankers to sometimes get boring. :wink:
As we are comparing engines, why did Jaguar need a 5.3 litre short stroke V12 to get 242hp and 295 ft/lbs when Porsche beat it on both counts using a 3.6litre flat 6, or Mitsubishi using a 2.0 turbocharged in line four.
Now here’s the thing, BL truck and bus was controlled by the idiots in government, they had a factory that built engines for their lorries and that’s all they had, there wasn’t any money to do anything but use that factory, they couldn’t buy in a complete range of engines and they didn’t need to as they sold every lorry they made, they didn’t give them away, people paid money for them, which is how it all works and the reason they build lorries in the first place.
There is no need to build the most Carlos Fandango engine, there is a market for a cheap and cheerful no frills lorry, which is how the Axor came about, as did the 85 Daf, which actually bankrupted Daf, that Leyland managed to build a complete range of lorries (T45) using basic designs from the 60s with a few modern touches is quite remarkable really.
newmercman:
Facts are boring stick to fiction , don’t forget Volvos 2.0 4 cylinder engine mine puts out 235bhp
newmercman:
Why did Triumph stroke the 2000 6 cylinder motor and Jaguar/TWR the same in the case of the V12 ultimately winning Le Mans with an NA production based motor v turbocharged Porsche.
youtube.com/watch?v=CCd7if8eRsU
youtube.com/watch?v=dPf0Dkm2Tko
youtube.com/watch?v=CFVOXsVN97Y
The speedo is the dial on the left and calibrated to 160 mph and that ain’t 242 hp or 0 - 60 mph. :wink:
ramone:
You mean the 2.0 82 x 93 mm 4 cylinder.That Volvo motor ?.
ramone:
I will take your word for it i’ve never measured it , but it goes well for a big 4 x 4
double post
newmercman:
This is exactly the point. In 1968 when Leyland were introducing the 500 engine and presumably had it in design for some two three years before, there was no reasonably predictable demand for for an engine producing in excess of 400bhp it would be in excess of some 30 years before this power output became required. Look back the same amount of time and we are talking pre war - an era when less than 100 bhp was the norm and much over that figure was the exception, the idea of requiring 200bhp would have been a pipe dream in 1938.
In 1968 for the 500 and still in 1978 for the 12.4L engine, Leyland was looking to meet mainly current demand from its loyal customers, and a reasonably predictable future demand from those same and a crystal ball supposition for what might be required in the next 10 to possibly 15 years time. They were led by the development of the UK Motorway network and speculative predictions regarding any increase in gross vehicle weights.
Above all they were concerned with what they could sell, produce themselves and not be reliant upon external component suppliers. As they progressed through these ten years (68-78) they had observed the ■■■■■■■ Vee engine debacle, knowing from their own experience the financial cost that multiple failures in service and product withdrawal can bring. They were anxious not to be put in the position of meeting warranty claims actually relating to a supplier’s product. They remained averse to proprietary engines while allowing their more or less specialist Scammell partner to provide feedback relating to Rolls Royce and Detroit and Guy with feedback from ■■■■■■■ and Gardner as well. They had watched the rise in market share of ■■■■■■■ inline engine at the expense of Gardner elsewhere and within Guy and were very glad to be free of the supply problems that any involvement with the latter company would have meant for their own production. They had also witnessed the continuing refusal of the very conservative home market to accept the thirsty Detroit and noticed similar resistance in some quarters to the inline ■■■■■■■ for the same reason.
It had been an extremely frustrating period trying to forsee power unit requirements for the future, they had had legal issues with patents, around a vee engine design, which they considered had contributed to their own vee’s demise and withdrawal. They had run into trouble trying to uprate their 11 litre engine by turbocharging. With a continuing somewhat strained relationship with their AEC partner they had decided that it was to be a Leyland clean-sheet 12 litre design to take them forward, but the V8 episode had left them in even more of a hurry. Meanwhile as a sop to AEC they would let them investigate uprating their 8.2 litre design for medium and medium - heavy weight vehicles. A realisation of the cooling requirements for their new baby under their existing cab caused a drastic rethink. They would cancel the 8.2 litre AEC upgrade and downsize their project to make it fit.
This left a somewhat disgruntled partner and a problem with how to replace their largest engine. A look at the overwhelmingly important aspect what was selling in their portfolio showed that their Freightline Beaver was outsold by AEC’s Mandator. So considering their view was that the Beaver’s engine upgrade had been unsuccessful and not worth persuing, then they would concentrate on the large AEC unit which seemed good to take them as far into the future as they could see. There was one manufacturer they had been observing from afar whose ideas might be worthy of possible consideration for their own experimentation - Mack and the concept of turbocharger tuning and torque rise. Their experimentation with the fixed head 500 engine had provided valuable knowledge, this would be used in the development of the TL12.
With the closure of AEC production in 1978 Leyland found GUY customers still loyal to an outdated product cab, but one which had offered proprietary engines. This provided an opportunity to market an updated Marathon utilising much that had been GUY, the option proved popular sowing the seeds for a potential abandonment of the TL12. Meanwhile Leyland were stuck with trying to develop and iron out production quality issue with the 500 series engine which they eventually more or less achieved with the final version, only to be taken over by DAF with the immediate substitution of that company’s 8.25 litre engine into the T45 cabbed chassis.
cav551:
:confused:
The L12/TL12 were both 1973 introductions.
A Conservative production life would be 10 years realistically 15.
10 hp per tonne wouldn’t have been an unheard of aspiration at that point in time among the enlightened.
So 300 hp + not 400 hp at even at32 tonnes and what they knew would be coming eventually would have been a good benchmark to be aiming for to future proof the thing.
It’s also a truck engine not a formula 1 engine so it’s the diametric opposite design aim of as much power as possible produced at as low rpm as possible, from an engine with as good durability as possible.
So that’s the 500 gone and knocked on the head by 1970 before we even start on the new ‘TL12’.
So we’re taking our design cues from the Maxidyne 676.Oh wait it’s an 11 litre motor of 123 x 152 mm architecture.It’s also got inter cooling from the start.It puts out 285 hp at 1,800 rpm 1080 lb/ft torque at 1,200 rpm.
Making it clear that Mack understood the need to maximise the leverage side of the equation and then some to maximise their torque aims within their design and a turbocharger without inter cooling is also mutually exclusive with that.
It’s obvious that the TD120, Rolls Eagle, and DAF DK were all contemporary designs and all got closer to that ideal one way or another and in fact improved on it regarding specific outputs.
But not one AEC designer said, that just boring out this bus engine 590/690 based block again ain’t going to cut it in that regard.
While increasing boost pressures with intercooling to compensate was obviously just going to add to the resulting problems of too much stress through the con rod.
Or did they. :open_mouth: :unamused:
Took their cues from Mack yeah right not with the 590 based block they didn’t nor could they possibly have done.
I can’t think of another British manufacturer offering 320bhp engines as standard in 1973. The 140 Scania was a rare and too heavy option but not a run of the mill fleet vehicle . In the '60s 6 wheeler units were appearing in anticipation of weight increases that never happened. The average unit of today pushes out between 440 and 460 so the 10 bhp per ton is still regarded as the fleet norm.
In hindsight Leyland should have turbocharged the 760 much earlier instead of bothering with the V8. By `73 they could have expanded on the TL without the nervousness they had instilled in many hauliers , but of course hindsight is a wonderful thing. The TL was a very good engine and when compared with similar output vehicles could more than match many of them . The L12 is the one that puzzles me when the AV760 was already there, it was a duplication of engines
ramone:
But a design ‘introduced’ in 1973 wouldn’t have been based on what was ‘standard’ in 1973.
The L12 and TL12 weren’t actually connected with the 760 according to Gingerfold.Which makes sense or the 1973 ‘introduction’ date would have been irrelevant.
Cav provided the smoking gun in his comments regarding the Maxidyne being their reference point.
At which point any designer worth his salt would have said the 590 based 760’s architecture won’t cut it.
While ironically a 12.5 litre motor based on the Maxidyne’s design aims and bore stroke ratio and inter cooled from the start and resulting similar specific outputs would have smashed the competition into oblivion probably well into the 1990’s.Nothing could have got near it. :frowning:
ramone:
You have got to start reading posts , in `73 very few standard engines in fleet form pushed out 273 bhp, the Marathon did prompting Volvo to introduce the 290 , the L12 and TL12 were based on the AV760 but were a big development compared with the AV760
Again we fail to understand what the TL12 was designed, built and sold for. It was to go into the lorries ran by Leyland’s customers. It was never meant to be groundbreaking, never meant to win Top Trumps, it was a relatively unsophisticated engine based on a proven design and you know what, it did exactly what was required of it.
The end.
However it won’t be the end will it, oh no, our all knowing friend from junction nine will continue on his crusade to rubbish everything that came out of the Leyland stable in a deluded attempt to blame designers working on a limited budget thanks to the car division swallowing all the profits to keep on producing the complete and utter crap it made, that is on the few days when it was actually working and not striking.
We will compare it to every engine ever made to bring attention to its shortcomings, even though the author of these endless tirades has absolutely zero experience of any of the “superior” engines he uses as comparison, with the exception of the Daf DK series.
The reply to this would most likely have started with a to be fair, yet there’s nothing fair about it is there, every other participant has contributed positively to this thread, not always glowing reports or claims that the TL12 was the best thing since sliced bread, but positive in the way they conduct themselves and then like a pigeon playing chess, Carryfast turns up and the excrement contacts the air distribution device.
To add insult to injury, the thread is about the Leyland Buffalo, you couldn’t make up this up ffs.
ramone:
Yes, you are quite right we are still hovering around or slightly over the 10bhp per ton mark, but that applies especially to those vehicles on full weight work, huge numbers of vehicles are in the postage parcels and similar where they often run round loaded at near enough the same weight 6 axle bulk carriers tare off at, but have the same engines as those regularly running at max weights for probably the majority of cases, for vehicles on such work the following does not really apply.
I know this isn’t the thread for this discussion, but with the traffic levels out there and the speeds modern traffic take roundabouts and junctions at, it’s increasingly difficult for vehicles running heavy at the magic 10bhp per ton mark to get moving quickly enough.
It isn’t so much the bhp figure, which only really comes into play when the engine is pulling from somewhere near its peak torque revs, its that to all intents and purposes fleet spec motors up to and including 500hp rated engines are no bigger in swept volume than those old 70’s and 80’s designs and in many cases smaller still, hence no sheer guts to get the thing moving from standstill, coupled with awful automated manual gearboxes even if overridden manually by someone with nous still take too long to select the next gear and resume power.
Anyone who drove decent 14 litre ■■■■■■■■ will know whats missing regarding lugging power to get the modern stuff moving, even the humble Buffalo could be relied on to get shifting rapidly away @ 32tons, helped it must be said by the slick fast changes that Fuller box allowed.
Sorry for the thread drift by the way.
