I dont think thats why its called the "fifth wheel" love!
@ the 20% weight comments in this thread. :unamused: Some people will believe anything.
Harry Monk:
IIRC, a typical fully-freighted artic with tri-axle trailer will show an axle weight of around 8 tonnes per trailer axle. A loaded trailer weighs around 36 tonnes, (44 tonnes minus the weight of the tractor) 24 tonnes of this is borne by the trailer axles and so around a third of the weight is borne by the fifth wheel.
They also used the term in the states when we were still using mainly rigids and their typical configuration has always been 5 axles 3+2.But having said that the 20% figure seems to be a breakpoint minimum to seperate an artic and it’s coupling from ballast tractor trailer or drawbar outfits :question:in which case the term seems to make some sense although common sense would prevent anyone confusing the different types anyway and the terms tractor unit and semi trailer outfit versus the different types of truck and trailer outfit have been in common use just as much as the term fifth wheel and there’s no way that anyone could confuse the different types or their coupling designs.
FWIW it says this on Wiki…
The term ‘fifth wheel’ comes from a similar coupling used on four-wheel horse-drawn carriages and wagons. The device allowed the front axle assembly to pivot in the horizontal plane, to facilitate turning.
A horizontal wheel or segment of a wheel called a fifth wheel sometimes forms an extended support to prevent the carriage from tipping; it consists of two parts rotating on each other about the kingbolt above the fore axle and beneath the body
Harry Monk:
Wiki is written by users, so info on it should be taken with a pinch of salt, but sounds about right to me?
What I don’t get, why would a driver be asked this question to get a job driving a truck?
Can you drive this vehicle? YES. Do you know rules n regs? YES. Do you know why it’s called a 5th wheel? NO. Sorry then, we can’t get you any work?? :question:
waynedl:
Harry Monk:
:laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing:
That just about sums it up for me as well Wyane. All these assessments and BS questions serve no useful purpose at all.
I always thought that it was called a “fifth” wheel because it was invented by Horatio charles edward Fifth, Inventor, (1893 - 1977). he is also credited with the dog clip, invented so he could release his pet poodle Gregory from it’s leash quickly. Among the other benefits he bought to the transport industry was the Bulldog clip for fixing number plates to the rear of trailers, and of course his most famous invention, The clip on tie, as commisioned by Eddie Stobart.
Explanation.
http://www.worldlingo.com/ma/enwiki/en/Fifth_wheel_coupling
Harry Monk:
In which case then a drawbar trailer has a fifth wheel coupling just the same as a semi or a composite trailer. :open_mouth: :laughing: :laughing: :laughing: :unamused:
Harry Monk:
But more generally known as a turntable.
Fifth wheel coupling invented by a bloke called Big D from York :laughing:
Harry Monk:
Hopefully those birds in that office will be reading all this. :laughing: :laughing: But only the British could have invented a coupling used for artics in a country where rigids and/or drawbar outfits (with turntables) ruled :open_mouth: :laughing: .But some say that it was a bloke called Charles Martin who came up with the idea.
roadtransport.com/blogs/big- … -fift.html
truckerjon:
Given his choice of canine companion would he not have called it a Poodle Clip Instead of Bull Dog Clip. Unless Gregory had sadly been run over by a runaway 5th wheel and he had a new faithful friend by the time he started on his clip inventions?
Coffeeholic:
truckerjon:
He did plan to call it the gregory clip, but someone had already used that name on a device for keeping a bishops mitre in place. He did want to call it a poodle clip, but fortuneatly was persuaded otherwise. Gregory did tragically die as a result of an electric shock from a pair of faulty curling tongues and, being British, Horatio got a pet bulldog called Nigel.
truckerjon:
Coffeeholic:
truckerjon:
Thanks for clearing that up, I’ll sleep easy tonight now.
truckerjon:
Coffeeholic:
truckerjon:
Some say that Nigel met it’s demise while trying to carry out a vicious attack on some fit looking birds in a transport office while his owner Horatio was demonstrating his new invention for attaching number plates to trailers.By all accounts those birds showed their gratitude afterwards to the lucky zb who rescued them from Nigel.But those birds swore ever since that it was a runaway fifth wheel not a bull dog which almost got them.
For whats its worth…
Steve
neversweat1:
Steve
Er, not much actually :wink:
That is a description of an articulated vehicle, not a fifth wheel.
You will also note, it says “Not less than 20%” i.e. more than 20% is to be carried by the towing vehicle.
+1 for the 'osses :slight_smile:
A1ex:
neversweat1:
Steve
It’s also a description of a composite trailer because a dolly has a semi trailer superimposed on it by using a fifth wheel coupling. :open_mouth: :laughing: :laughing: :laughing:But a horse cart and a drawbar trailer both use a turntable.Unless there’s a horse cart somewhere with an artic fifth wheel coupling attached to the drawbar In which case it would be a composite trailer pulled by osses. :laughing: :laughing: :laughing:
A1ex:
neversweat1:
Steve
Unless it hasn’t…then it isn’t :confused:
truckerjon:
A1ex:
neversweat1:
Steve
In which case it’s a drawbar trailer with a turntable pulled by osses. :laughing: :laughing: If you can’t baffle em with bs blind em with science. :laughing:
Eeh, you young uns know nowt. When I started driving there weren’t many artics about. They were just starting to come into service and replacing rigids or wagon and drags. Virtually ALL the early artic units were four wheelers, (well OK six with the double wheels at back) one on each corner and the fifth wheel was the turntable. Most trailers were single axle. The maximum weights had not been changed and were the same as on rigid vehicles. We didn’t have the advantages of 'Elf n safety regs. These came later. Because of this and the old fashioned regs most Artics at the time were limited to the same weight as rigid 6 wheelers.
The idea of 20% loading on the turntable may have come in later, (we didn’t have it before decimalization and them Kilomometers) it probably came about because when the early artics were loaded if you didn’t get the weight distribution right they tipped up when the unit pulled out when dropping trailers. The single axle at the back couldn’t counterbalance a badly loaded trailer or a part loaded trailer if the weight was in front of the landing legs, so they altered the regs to protect you young uns.
I worked for Hanson Haulage and when we used to go out to load night trunk vehicles (artic vans) we had to load as much as possible upfront when out collecting and then back onto the loading docks in the depot to top up. Obviously you didn’t want to be moving heavy stuff twice so it had to be loaded up to the headboard as much as possible. We used to shove a 45 gall drum and some planks of wood under the front of the trailer when the unit pulled part way out to stop it tipping. You can’t report me for breaching 'Elf n safety rules cos they hadn’t been thought of in those days. You young uns don’t know how lucky you are. :laughing:
