Like this wee beautie?
Height = 1535mm
Track = 1380mm
Height = 1535mm
Track = 1380mm
Coffeeholic:
weeto:
According to an ex copper on a non truck related form, his understanding of a high sided vehicle would be âany slab sided vehicle taller than itâs widthâ.Thatâs always been my understanding as a rule of thumb, minus the slab-sided bit, any vehicle that is taller than it is wide.
Is that his opinion though, or is that written in legislation, or is there case law to support?
Just if anyone ever ended up in court with a dispute over high sided, âa mate whoâs a copper saysâ isnât going to cut the mustard!
cieranc:
Coffeeholic:
weeto:
I doubt you you would end up in court for using a road or bridge which was saying it was closed to high siders, but if you did use it and got blown over you probably would, for driving without due care and attention.
Before all this H+S â â â â , at the forth bridge they would ask fully loaded trucks to cross on the wind side carriaige way to give protection to light vehicles from the high winds as they crossed, now I doubt they would because of the sueing culture.
weeto:
Before all this H+S [zb], at the forth bridge they would ask fully loaded trucks to cross on the wind side carriaige way to give protection to light vehicles from the high winds as they crossed, now I doubt they would because of the sueing culture.
I was âescortedâ over the Forth Bridge like this once, by an artic tipper. I was on my motorbike and sidecar. Trouble was, the car that I was being escorted across with was so far back, alongside the tippers trailer axles, that I was just left out behind the trailer, getting buffeted by the wind
I havenât seen it in many years now though, at least 10, so I reckon your right.
cieranc:
thelorryist:
Well (donât quote me butâŚ) I think a vehicle has to have an indicator over 9 footprint something⌠So wonât that be it?You mean the height indicator in the cab?
What if thereâs no trailer, and the unit is a low cabbed 9 foot 6 jobby. Still a high sided vehicle?
He said âdonât quote meâ
Slow Down Fog, but fog in whose eyes? to some it is a bit misty
Animals Crossing, How many?
Old Peoples Home. Ageism or a statement of fact
High Winds. Over 9 feet or what?
dazaster:
the m48 high siders was classed as anything over 6"9 yesterday
yes,i saw that also!
Harry Monk:
cieranc:
Harry Monk:
Yes, it seemed a reasonable question to me.Mee to Harry, hence:
vwgpmk2:
You taking the â â â â ?cieranc:
YesNo such thing as a stoopid question
Apologies, internet mis-understanding!
Apologies as well.
it just seems such an open ended statment, âCLOSED TO HIGH SIDERSâ at least if they put a height everyone knows what they are doing
HiyaâŚshould it be slab sidedâŚthink on!! a 15.6" tautliner with the curtains fastened back(megga job)
suddenly becomes ok to drive in high windsâŚwell it used to before all this H&S and construction and use thing.
when windy i always made sure the curtains was tight as a drum skin⌠when the curtains are not very taut
they catch the wind. i saw a truck go over one day. it was fully loaded 20 tons of spuds the sides was slack
and the wind got caught in his curtains and just took him over.
When it says on the radio forth road bridge closed to double deckers then you check the FRB website it says closed to double decker buses only, in height terms what is the difference between a double deck trailer and a double deck bus if anything they are the same height?
my gaffer sayâs cos im under 13â 3" im not a high sider, so seems a good question but no definate answer.
i have never known a loaded traiiler being blown over even if the sides were loose.
My opinion is if you have 20 ton on a trailer it will never blow over !!!
3300John:
If the trailer has no back doors (like a double deck) you canât fasten the curtains back though.
cieranc:
3300John:
HiyaâŚshould it be slab sidedâŚthink on!! a 15.6" tautliner with the curtains fastened back(megga job)If the trailer has no back doors (like a double deck) you canât fasten the curtains back though.
Yes you can if you carry rope as i did. i had up and over door I fastened the curtains to the back pillars
to which your not supposed to do but i had a lump of timber i jammed into the door. anything to keep moving was
my gameâŚas you say its a bad idea if theres no back doors as the wind gets into the backpanel and lifts the
back end of the trailer this can lift the roof panel outâŚanyhow it was the flat or slab side was the issue.
Cheers John
merc0447:
Double deck busses when I drove them ranged from 13â6 - 14â9 according to the in-cab height stickers, but even identical busses had different heights inside, and park a 14â9 next to a 13â6 and there was nothing in it, must depend how and where measured or something.
Remember doing a route in a 14â3 double deck, and it broke down, they swapped it out for a 14â9 double deck, I slammed on brakes approaching a 14â6 bridge and phoned the boss, he told me theyâd all been tested and it was fine to go under, had someone upstairs guide me under, over a 1â clearance.
Double deck trailers usually 15â6 upto around 16â3.
3300John:
Cheers John
Aye John, meant to say, you can physically tie the curtains back, but the problem with no back doors is the wind comes in the sides (no curtains) hits the back doors and deflects upwards, ripping that thin ally sheet roof off.
Repaired more than a few trailers thatâd had the roofs blown off due to this.
cieranc:
Do you really need to ask? Could you not just apply common sense?Is a loaded container a high sided vehicle? Is an empty double-deck?
If you need the Highways Agency to tell you whatâs safe and what isnât,âŚ
Perfect answer
Itâs just a matter of common sense. I have driven with 16â3" tautliners that when loaded will not even sway but when empty will be turned into a sailing ship on land.
One night in the 90âs when an un-forecast hurricain struck England Swifts had 6 of them blow over on the M25.
cieranc:
3300John:
Cheers JohnAye John, meant to say, you can physically tie the curtains back, but the problem with no back doors is the wind comes in the sides (no curtains) hits the back doors and deflects upwards, ripping that thin ally sheet roof off.
Me too, even bulk boxes with polycarbonate roofs when the hatches were left open after unloading
Pat Hasler:
cieranc:
Perfect answer
late 80âs hurrican fish
jessicas dad:
Pat Hasler:
cieranc:
Perfect answer
One night in the 90âs when an un-forecast hurricain struck England Swifts had 6 of them blow over on the M25.late 80âs hurrican fish
Yep ! Micheal Fish got a roasting for not forecasting it
