ecilop:
Few things to check Si.
first is it a 4x2 or 6x2… if its a 6x2 tag check cross members very carefully these have a habit of cracking.second… check the bell housing and look under the turbo manifolds the bolts have a nasty habit of working loose and if left can mean a new bell housing, tell tail signs oil leaking from top of the bell housing areas and runs down the sides of the block, can have been washed off etc so keep a eye on that, it isn’t a very hard job to do but its a good day to by yourself to take off and re fit etc, if all goes well that is.
third, mileage pending? for what it costs have the bottom end rebuilt or do it yourself, a good mornings work that’s all to replace big ends, mains etc, gaskets and maybe oil pump, and new oil, cost of bearings and gaskets around £300. ISH… keep the oil spinner clean " we do ours at every inspection anyway same as fuel & oil filters,
rest normal Scania probs, wiring by steering box. cab bushes, and wiring on n/side esp for the range change apart from that its all good,
its a 4 x 2
- ive got 3 months engine/gearbox/rear axle warranty so hopefully a little time to find any faults
as soon as i get her its going in for an inspection before she hits the road
