Glasgow Transcontinentals
@alexsaville I did a wee bit of searching last night on the balmore road site. Certainly closed for waste intake, I think it closed to waste around 2002. In 2006 there was a big hullabaloo due to water from the site contaminating a local water source used for fishing. They are currently capping it a bit at a time. Seemingly there is a lot of methane which they somehow harness and use to run diesel generators. These produce electricity which they sell to the grid. As for where they use now for landfill I couldn’t say for sure but, when I worked in Falkirk I used to see a good few of the CFs with the tipper trailers going up and down the M80. I assumed they were going to the I and H brown site that you pass heading towards Falkirk but I couldn’t confirm that for sure.
Sent from my SM-G973F using Tapatalk
Interesting Topic & sorry for butting in.
Hi Chap’s, closest I can think of to Edinburgh Airport, is Avondale landfill at Polmont which was an open tip, but thought that had all stopped now. A lot of ejector type lorries from the west travels through to Oxwellmains site at Dunbar, East Lothian, were they have been filling the old limestone quarry for approx 20 years, also a big incinerator built in the last few years. I’ve done both livestock - general haulage going onto farms, and bin work driving onto landfill sites to empty, and double drive would certainly have helped at times, 1 yard in the soft stuff of plastic bags, old mattresses etc and you’d know the benefits of D/D. Hope of some help. Bobs
dieseldog999:
remember they were council workers,so there wouldnt have been a lot of driver input or initiative required.
id reckon they would need a double drive setup as mush as the tesco plobbers need the plastic shovel they all get issued with.
most likely someone in the council got a nice backhander from wylies commercials. :wink:
most of these humble council workers are probably retired now on nice final salary pensions, how about you?
pollystag:
dieseldog999:
I won’t get drawn into your brown envelope scenario but I can tell you that some of the tractor units that we rented to them came back with so little mileage on them I doubt they even left Polmadie. I spoke to the TM about this and he explained that the dept worked on a fixed budget that had to be spent. For some strange reason it was ok if there was an overspend as that was put down to “operating conditions” but an underspend would result in the budget for the following years being reduced. Maybe they just had to spend, spend, spend and it wasn’t necessarily corrupt (although I wouldn’t rule that out). We had a few big transport companies that we used to supply to at the end of their financial year that seemed to follow this practice. In fact, if I’m brutally honest, BRS (and indeed the whole of the NFC) was run on a similar line at that time - this was pre-privatisation days we’re talking about. Making a profit only put you under pressure to repeat it again the following year but a loss was somehow acceptable. I got pulled up by my director shortly after I had taken over one of the branches and asked why I hadn’t submitted any expense claims. When I told him that I didn’t like any of our customers enough to spend an afternoon getting ■■■■■■ with them he said that it was reflecting badly on the other managers. I think it was at that point that I decided my future career should go in a different direction.
Been a while since I’ve been active on this thread however I came a cross this still from a short film about Glasgow council. What appears to be one of the GCC Transcontinentals on High Street
What’s the blue car i the foreground, it looks French?
It’s a Rover SD1 mk1. I can’t make out the model, if you can get a larger image the right hand silver plate on the back gives the engine size.
2300, 6 cylinder
2600, 6 cylinder
3500, V8
The left hand plate just says ROVER.
After checking the number plate, why didn’t i do that first, it’s a 2300. Interestingly it’s had a respray, when it was first registered, March1979, it was white.
I thought it looked a bit Roverish, the trims under the lights giving it away. Ive never seen one with lights like that, it makes it look narrower and a bit Peugeot/Citreonish.
