newmercman:
You a bit of a boy racer on the quiet then Carryfast
I get that impression
I myself like a lorry with a bit of oomph, my own purchase history contains a 470 F16, a 480, 520 and a few 540 IVECOs and of course the best of the lot, my little 143, but, and that’s a big but, I don’t expect to climb hills as if they weren’t there, I’m in a lorry FFS, so I’m going to slow down, if I drop 5mph or 20mph, it doesn’t really make much difference at the end of the day. I used to do a trip to Italy every week for years, I did it with a two ton load in a 480 TurboStar and I did it with 26tons of Copper Wire in a 1729 Merc, it was a bit quicker in the big FIAT, but that gutless windbag of a Merc still got me down there and back in a week
I also spent a lot more money on tyres, brakes and fuel running those top of the power range lorries than I would have with a more basic fleet spec lorry
All this 10hp per ton that you keep saying means is that anyone who runs at anything less than full weight with a 440hp lorry is an idiot and anybody who buys anything with more than 440hp is an idiot unless they’re doing heavy haul
I reckon that back in the 70s there were ten times as many Daf, Scanias and Volvos repossessed as there were Gardner powered lorries, the saying “all flash and no cash” springs to mind…
You’re never going to climb hills as if they weren’t there with 10-12 hp per tonne but you’re going to get over them a lot easier and more efficiently with that amount of power (so long as it’s the type of power that’s made by multiplying loads more torque by around the same engine speed hence you’ll need something that can be turbocharged and stand up to it).
Anyone who buys a 440 hp wagon to run at less than max weight isn’t an idiot just so long as they don’t use everything that’s available most of the time.Although when there’s a few hills thrown into the equation the more power (torque) that you’ve got,relative to the weight you’re hauling,the more fuel efficient and productive the wagon will be because all those faster average speed journey times add up over the course of a year while the idea of increasing the power (torque) to weight ratio,has been the basis of truck diesel design for at least the past 42 years and,so far,no one seems to be saying lets get back to naturally aspirated diesels with around 5-6 hp per tonne because we’ve been going backwards,in terms of truck diesel efficiency,since the end of the 1960’s,not forwards.
As for me a boyracer.The average boy racer wouldn’t dream of using an old modified 1980’s BL built,almost 1.8 tonne Jag XJ saloon, with ‘only’ around 350 bhp,because they’ve grown up being fed all the Thatcherite bs about useless British car manufacturing workers and the power to weight ratio on paper is no good
.While forgetting that the difference is the thing is putting out that figure at less than 5,500 rpm so it will last longer and it’s puttting out around 400 lbs/ft of torque at around 3,000 rpm so it really does climb hills as if they weren’t there and leaves those mickey mouse hatchbacks of the line as if they were standing still helped by chucking the auto box where it belongs in the skip and lowering the final drive ratio while the 5 speed manual box still lets it run at lower rpm at 165 mph on the flat than it did before with the auto at 150.All that without bothering with turbocharging or supercharging.Hugh Gardner would have been proud.
