Hi Chaps,a bit of info for you a site worth looking at is British pathe they have a couple of short films made for sunblest in 1963 lots of allied mills companies on them.
Thats why I saw a car parked in there behind locked gates. What are they going to do to it, flats?
Oldacres mill at Ducklington closed years ago was talk of it being listed but was demolished just before 2007 floods. A workmates Dad worked there said they’d concreted in an old mill pond. Cue demolition gang breaking up the hardstanding during all that rain was like drilling a hole in a boat!
Dont know all the basement,ground floor,garage,warehouse and yard flooded in 2007 for the first time since 1987 when the yard was redevloped and a 2ft extension was fitted after the 1998 flood came close!!!So its a bit of a mess inside.Will have to wait and see what its turned into.
Muckaway:
Does anyone remember MARDORF PEACH they were rice millers part of ABF which also owned ALLIED MILLS and today come under the Westmill foods name which is part of ABF.Any info and photos would be great cheers flourpower.
Hi does anyone know if i can buy the A smith automodels LEYLAND 8 WHEEL TANKER in SPILLERS LIVERY stilll or does anybody have one for sale?Do the same company do some HOVIS motors too?any help would be great cheers flourpower
Hi does anyone have photos of any European flour millers eg RANKS MEELfrom Holland etc?Would be interesting to see any photos.Also have any one spotted the UK ALLIED MILLS 50TH ANNIVERSARY TANKERS on the road?
cheers Flourpower.
FLOURPOWER:
cheers Flourpower.
Hi Keith - I might have a ride into Manchester with my camera soon - see if I can spot one of those tanks at the mill.
FLOURPOWER:
cheers Flourpower.
Hi Mark,have you seen the photo on Flicker of a 50th anniversary tanker if you type in flour tanker in the search i comes up.also theres a very nice 8w erf b series tipper of rankins on e-r-f photostream also on flicker.cheers keith.
How did they go with axle weights? The ones I operated were all three compartments, with the hot pipe plumbed to the top, discharging from a manifold to the bottom of each compartment. Discharge pressure depended on the product. They didn’t need to tip.
If I recall no issues with axle weights J337 KKE (4x2) & triaxle tank tared off at just under 14000 kg, got a nice tidy 24000 product on. The tandem axle tanks could take a max of 20000kg loads.
These were unloaded by applying the tank park brake, releasing the tractor handbrake, the tractor then was pulled backwards as you raised the tank.
Not unknown, but very rare for a hydraulic hose to split as you tipped the tank and the tractor to be pushed forward as the oil escaped (was not a fan).
All were single compartment , some with a single baffle above the 5th wheel, rear outlet tanks, newer ones started to come with top air supply.
One the 3 8 wheelers had 2 compartments, had to blow out the front one first…if you did the rear first, the product could sit against the rear wall of the front tank and the tank could not be lowered…
[quote=“star_down_under, post:496, topic:198932, full:true”]
[/quote]
Hi
Slightly off topic but does anyone recall Millenium mill in Silvertown being used to collect bagged animal feed. As a kid i webt somewhere in London with multiple conveyor belts where bagged feed was feed to the driver who handed it onto his truck by the truckload, my dad was one of those. Id love to know if im right and if pictures exist of this set up…cheers
