Lawrence Dunbar:
robert1952:
@ ‘littlerichard’: nice contribution old mate. I reckon the E-series ERF was one of the best ever. It was brilliant with the Twin-splitter in and even better with the Fuller. You mentioned a bit of tension between the Twin-splitter and the high torque of your tweeked E14. About that time Eaton sorted the problem out by beefing up the TS 'box to cope with the big ■■■■■■■ engines in the export models. Keep 'em coming!
@ Lawrence Dunbar: your usual excellent contributions seems to have slipped between a couple of pints there! That’s no E-series ERF!!
Robert
It must be the Malts Im on tonight, But heres an E series just for you Robert, Regards Larry.
And a fine example it is too! Robert
steel bumper model looks much better than the plastic ones imo.
Punchy Dan:
0steel bumper model looks much better than the plastic ones imo.
I assume that’s a tag-axle… Robert
robert1952:
Punchy Dan:
I assume that’s a tag-axle… Robert[/quote
That would be a 6x4 - they operated a few IIRC
GCR2ERF:
robert1952:
Punchy Dan:
[/quote
Thank you. Never drove a 6x4 on the road. Would’ve liked the opportunity. Robert
robert1952:
GCR2ERF:
robert1952:
Punchy Dan:
[/quote
They’re alright when they’re loaded… not so clever when empty or solo
GCR2ERF:
[quote="robert1952
[/quote]
…Or taking bends and corners in the wet, I’m told! Robert
GCR2ERF:
robert1952:
Punchy Dan:
[/quote
That’s right double drive the above of Peters was E reg but Ernie Walker had one too at the same time but it sat so long in the garage it was F reg by the time it went on the road .
robert1952:
GCR2ERF:
[quote="robert1952
[/quote]
Not unlike a fully loaded tag on a wet roundabout
robert1952:
GCR2ERF:
[quote="robert1952
[/quote]
I can confirm that too Robert… as can the occupant of a house in Nuthall whose front wall I rearranged one wet night in November 1992 (!)
After reading the recent ERF book I started thinking about Eaton samt ,there doesn’t appear to be any mention on trucknet like pics ,first hand accounts from drivers / operators or other evidence ,also the E series must be ( I think ) the model that from its start underwent the most changes over the 7 production yrs many of which are still with us today such as plastic bumpers ,air seats ,air suspension ,engine electronics ,semi auto transmission,speed limiter,( some items I’ve missed ) but a backwards step not as much room for a double bunk !
Punchy Dan:
Pretty well everyone I’ve ever talked to who used SAMT (basically a semi-automated Twin-splitter) hated them; and as I’ve said elsewhere, they often had them converted to manual. I did post an article about a SAMT-equipped ERF on the LHD E-series thread a while back. Robert
Iirc the gearstick if it can be called that was on the bonnet in the same position as the deadman would be in a B series ?
Punchy Dan:
I think that’s right, though I never used one myself. Here’s a picture of an E-series interior with one. Robert
Robert were they avalible in the EC range ? I didn’t think so but I could be wrong , I remember BJJ cutting up a late air suspension model E series up which had a Samt .
Punchy Dan:
One day I had to return a SAMT E Seires to Peter gilders yard but didn’t have time to understand it. The following year I was doing Spain in a very early SAMT EC12 pre production truck, L15 JRT, one of Two in the all blue Jordon racing colours . It was far from perfect but I liked it and it worked well. There was a little screen telling me how many gears I could change up and how many down. It worked well behind the big rolls but I have not seen another since
ERF MAN:
Punchy Dan:
Was this the last time Samt was seen in ERF ?
robert1952:
Here’s a question for E-series afficianados. This beastie (D899 BRY) has been on the show circuit for a while now and I believe it has my favourite combination of 14-litre ■■■■■■■ (320 in this case) and 9-speed Fuller. It appears to have come from a sizeable fleet of ERF E14s in the service of Sam Longson. Were 9-speeders standard on their E14s, or was D899 a one-off? Robert
Apparently from gossip at our place, as there is a shed load of ex longson drivers, when the BRY’s came there was a 100 all lined up in the yard at chapel, with consecutive reg’s !
One of the smartest liveries about !
