When you’re just over the 4 and a half hours drving time as you pull off for your break does the Tacho not let you change driver 1 mode to break but keep constantly flashing about how you need a break? I just end up pressing all the buttons till i getback to the normal screen then change the mode fo driver 1.
truck76:
You should accept or ok the flashing, like you would an overspeed
and try to keep it under 4h.30
truck76:
When a warning shows on the display press “OK” on a Siemens or on a Stonridge press the button that looks like a return key to clear the warning, you will then be able to put the tachograph on break.
