rob22888:
robroy:
LGVStuart:
Can’t fault Jack Richardsons… more should do the same…Doesn’t Jack Richard’s do a lot of work for Smith’s packaging co ?
I was talking to a driver the other day (not JR’s) who said the Livingston branch have notices up banning drivers from ALL facilities, and they have installed a portaloo to get around it.
Don’t know about you lot but I hate those [zb] things, I’ve refused to use them before, telling them ‘When I see you use it, I’ll use it,.where are the proper facilities’'.
Thing is though, if that is a valid way of getting around the h&s rules, I bet more firms will do it, and you can sure as hell bet it will continue to be the thing there on after all this present situation is over.
Nothing like being pointed in the direction of a portaloo to make you feel like your regarded as a class below.
Alright for a quick ■■■■■ but the moment someone has a sit down in there & the sun bakes it, they become the pits. Also highly doubt them things hold enough water for every driver to spend 20 seconds thoroughly washing their hands & a trickle of cold water is hardly adequate anyway.
When the trapdoor opens welcome to hell[emoji106][emoji23]
