norb:
I now quiet enjoy proving you wrong ,and I guess the rest of the forum enjoy it as well
norb:
norb:
So I guess you will now admit you are totally wrong ,and maybe should stay away from what you do not know![]()
norb:
is anyone keeping score? 17 - 0 to norb â â ? come on burgers, try to get at least one
Bking:
Waste gates have âneverâ been used on heavy diesels and I must admit you people are full of [zb]
Variable geometry turbos can vary input load by turning vanes inside the volute to increase or reduce boost.
Now some Genius is going to tell me I am full of crap so tell me one heavy diesel with a waste gate.
Come on âexpertsâ
Youâre full of crap. To name just a few, from one manufacturer:
Cat C6.6, C7, C9, C10, C13, C27, C32, 3406, 3116, etc etc
Just the ones I can be bothered to look up, there are many more.
Ps, notice that I didnât include the C15 and C18 in the list, as they use balance valve turbochargers.
Bking:
Come on âexpertsâ
The Detroit Diesel 60 series had a wastegated turbo, I think youâll find thatâs a heavy diesel engine.
Is that enough or do you want more examples?
bking seems to have disappeared .Or has he realised what a fool he has been âŠThen again maybe just maybe he will be back on here Friday to tell us all how useless we are
norb:
bking seems to have disappeared .Or has he realised what a fool he has been âŠThen again maybe just maybe he will be back on here Friday to tell us all how useless we are![]()
maybe, the gobby â â â â has been put on pre-mod, and the mods canât be arsed with all his inane ramblings
we can but hope
Inane or in vane !!!
As I said âheavy dieselsâ have never used a waste gate turbo.
Waste gates are used on light pressure motors with spring biased âopenâ gates.
Love to see a 6 inch blower with âwaste gateâ
And I "suppose " the waste gate is biased shut?
So too much boost,broken actuator,blown donkey.
Broken actuator,no boost ,engine lives another day
Full o [zb]
Strange how you can have a âwaste gateâ and an exhaust brake on the same exhaust system
[zb]
Lock pressure in to â â â â â â the engine but then a waste gate to let it out
My â â â .
Bking:
As usual I will mostly be talking out ofâŠMy â â â .
Bking:
Broken actuator,no boost ,engine lives another dayFull o [zb]
I knew he would be back for Friday
I guess it has taken you a week to find that snippet of info ,after making a fool of yourself again.Afterall the thread if you care to look at the heading is âDAF turbosâ âŠAnd DAF use wastegates
Bking:
[zb]Lock pressure in to â â â â â â the engine but then a waste gate to let it out
My â â â .
Now I know youâre just a wind up merchant from that comment
Spoke to local DAF dealer yesterday and theyâre currently doing an offer whereby they supply a new titanium turbo and fit it for ÂŁ600!! A new turbo alone from them would be ÂŁ1400 so mines booked in for next weekend!
Matt
did you check to see if it already had a titanium turbo on it already?
shuttlespanker:
Iâm not sure but I told Daf that and theyâre going to check it out first. It hasnât had one done by Daf but there was a 2 year gap between it being on Daf maintenance contract and me buying it. Is there any real way of checking myself before it goes in as Iâm not what you would call mechanically minded!!
Matt
having never actually seen a titanium turbo, i really couldnât answer that
the best person to ask would be Norb
A titanium turbo!
Holy â â â â
Does it have a Waste gate?
You can smell the â â â â â â â â from here!
Bking » Sun Jan 25, 2015 12:22 am
A titanium turbo!
Holy [zb]
You can smell the [zb] from here!
Modern commercial vehicle turbochargers are subject to very high loads due to the wide range of applications they are used in. In many cases where there are extreme loads, a compressor impeller made of an aluminum alloy determines the service life of the turbocharger. In particular, material fatigue can result from extreme loads, especially when the loads are cyclical loads occurring at low frequencies. This phenomena is also known as low cycle fatigue (LCF).
Various measures can be taken to increase the service life. For example, the circumferential speed of the compressor impeller can be reduced by changing the aerodynamic design of the impeller or by controlling or reducing the charging pressure. High-strength aluminum, for example, that manufactured using the HIP technique, is often used to reduce variations in the strength of the material. The high-end solution using aluminum consists of milled compressor wheels which were also developed by BorgWarner Turbo Systems.
The increasing number of engine applications with high cyclical loads as well as the necessity to have higher charging pressures to remain within the stricter emission regulations have made an additional innovation step beyond the moulded aluminum compressor wheels necessary. In order to provide a customer with a technology that can withstand these loads and also ensure a service life that is just as long as it would be under standard conditions, BorgWarner Turbo Systems initiated a special development program.
The demands on the compressor impeller stated above make it necessary to use higher quality materials since the potential for improvement inherent in aluminum is just not sufficient anymore. The engineers at BorgWarner Turbo Systems decided to use a titanium alloy that is not only very hard, but also provides an excellent strength-to-thickness ratio.
With the titanium compressor impeller, BorgWarner Turbo Systems is now able to offer different compressor impeller technologies for special application requirements and special cyclical loads. In this manner the customer can select between cast or moulded aluminum compressor impellers or between cast or moulded titanium compressor wheels depending on the area of application.
Why not trot along and set them straight at Borg Warner, thereâs a good chap.
