Daz1970:
Best to use bed symbol (break or rest periods) if you can, presuming you can dispose of your time freely. The only problem with bed mode is some firms don’t pay breaks - that’s when POA should be ‘utilised’. But you still need a 45 mins break when 4.5 hours driving time is reached.
POA is not considered a break as you are effectively on standby. Except for double-manning purposes when driver 2 (non-driver) mode will always default to POA when vehicle is moving, and mode cannot be changed whilst vehicle is in motion.
VOSA state that the 1st 45 mins. of a driver 2 POA will be accepted as a break.
Write down the fortnightly driving time every morning and work out your 41/2 hrs from that. If the poa does reset it after 30 min when you have a break after 41/2 this probably won’t reset it, then you end up with 5 or 6 hrs on the clock but you now your ok if you work it out from the time you wrote down.
jondeere:
precisely drive! I write in my diary all the symbols/ minutes for each mode!
Daz1970:
klunk/■■■■■■■■
Never used POA, always on break.
Klunk
Nor me, I have, like another member have accidentally put it POA but changed it to break pretty sharpish!
POA is one of the biggest things that has screwed this job up for us all!
