A quick tacho question
I’m afraid I’m with you there the DCPC will not cure it and at best it is nothing more than a money making scam.
Norfolknewbie:
it never cured any thing just made my piles worse for having to sit on a hard chair for seven bloody hours :blush: :blush: :blush:
Norfolknewbie:
Way I interpret that bit ‘not required to remain at his workstation’ is that you could remain at your workstation through choice, it does not state -‘thou shalt not be at that workstation’. Maybe just a play on words but then which bits of the regs etc aren’t■■?
You can do what you want, you can sit behind the wheel, you can jump on the bed, you can walk over the fields, there is nothing in law that states you must leave or stay at your work station to qualify for POA.
However if it was me I would immediately select REST just in the off chance it runs over three hours. That way you can reduce your daily rest period to 9 without using a reduction. That may, help you to get back on track tomorrow.
