Had my first training session today so here is my training diary for all you nosey buggers!!
After my assessment drive a few weeks ago ( previously posted on the forum ) i started training today with Paul Tunstall of Lindley Green LGV Training ( heres the link to his site if anyone hasnât seen it before ).
paulslgvtraining.co.uk/index.php
I am having 4 hours per day starting today (8.00-12.00 ) and my test ( cat c ) on Friday at 10.15am.
Please bear with me if i ramble or make any spelling mistakes as not long got in from work .
Set of from home at 7.10am to get to Pauls yard for 8.00am, quick cup of tea and a chat to Paul and to his mate Roy who was taking another pupil for his c+e test in Pauls artic to help him out, into the truck, adjusted the seat fired her up and ready to go ( as i said i have had an assessment drive so was already a bit familiar with the truck).
Headed out onto the roads and Paul said he would take me around some of the test routes throughout the morning, nice steady drive, a few roundabouts, junctions etc, the main problem i found myself having was trying to master the gearbox ( slapover ), i found myself occassionally being a bit too rough with if and despite Pauls advice on letting the box do the work ( ie letting it flick to high range/ low range gently and letting the spring do the work ) i was being too forceful and there was a bit of crunching when dropping down from 7 to 5 and then to 4 etc
As the lesson went on i did manage to get it a bit better but still far from perfect
The drive took me around places i had never been before so was concentrating a lot on the route and also positioning etc, for a while when driving off i was forgetting my blind spot but after being reminded a few times by Paul it soon clicked and i was doing it every time i moved off.
Went to the test centre as Paul had to check on his other pupil in the artic so i had a look around at the reversing bay etc and the waiting room and a quick visit to the little boys room then it was back in the truck for a few hill starts, i did ok at these ( no rolling back)
although later on in the lesson i did roll back very slightly at 2 junctions
Spent about an hour driving on roads with different speed limits and lots of parked cars/ traffic lights and a few tight left and right hand turns, pretty sure i never hit any kerbs but i rubbed one on a tight right turn out of a narrow road when i got the truck to far over to the left when i gave way
Went to a large parking area off a main road in order to have a crack at the reversing manouvre, i had been a bit worried about the reversing despite seeing a few videos on the forum and reading lots of advice from you guys and gals so was a bit apprehensive.
Paul spent a few minutes measuring up and putting the cones into place and setting up a mat he has which is the same as the hatched area on the test, so i drove up to the starting cones ( keeping slightly to the left one ) and then Paul said to get left lock asap and reverse slowly at the same time, did this and stuck my head out of the window to watch the wheel near the line, checking mirrors and could see the centre cone, straightened the steering a bit and could see the nearside front cone of the âgarageâ in my offside mirror, bit of right hand down, bit more , bit more, eased it off checking both mirrors i could now see cones in both mirrors, straightened the steering and was more or less centre of the cones, Paul has a white mark on the rear arch and he said to get this level with the front of the âmatâ and this will be spot on, i took it slighlty over, applied the handbrake and got out to have a look and was about 3 quarters of the way over the mat with the back end so was happy with that, Paul made me have 2 more goes of the reverse and these 2 time i stopped with the white mark level with the front of the âmatâ and this was perfect. .
So after the worrying for nothing i did the reverse 3 times and all 3 were very good and not even half as difficult as i thought it would be!!! .
Anyway did a bit more driving and a bit more gear bashing and then stopped to have a cuppa
Did about another half hour of driving after that, around a few roundabouts, busy junctions and some long single carriageways to get it up to 40 and then it was back to base.
Lessons for todayâŚSlow down a bit earlier when approaching roundabouts
âŚGo gently on the gearchangeing
âŚAlthough using mirrors a lot still need a bit more!!!
Learnt todayâŚHave sussed the reversing ( hopefully!!! )
âŚHill starts ( did about 3 and all ok)
âŚChecking the blind spot regularly.
âŚPulling up at the kerbside.
Paul if you read this feel free to add any comments ( good or bad ) and this goes for anyone else if you are still awake after spending the last hour reading this!!!
Anyway totally knackered now because as soon as my lessons finish i am straight back to work paving and didnât get home til 6.30âŚgoodnightâŚzzzzzzzzzzzzzzzzzzzzzzzz
