in thru gate 2, over the ■■■■■, round to the left and drive towards the end
round a bit of a 1 way, and 92 shed on left where the workshop is, (nice blokes in there)
drive up to the booking in booth, the little white one has a window either side and is open from 16.00-20.00
all other times drive up to the main building, there is a window there
to the left of white building is where units waiting for trailers are parked (you can park the night here, unit only, the reception for telly is crap and there seems to be a million seagulls screaming their heads off) the canteen and toilets are in the building just past the trucks on the left side of photo (looks like its under a crane)
book trailer in your dropping and book out the one you are collecting (takes a minuite) and go thru canopy
containers over to the right
your receipt for trailer tells you which row to drop/collect your trailer (all lanes are marked alphabetically) you can ask for a map of where the lanes are if you havent been before, but they are clearly marked in paint on the ground in big letters either end of each row
some random pics here of the veiws
drop trailer, pick up trailer, no seal on back so check load is ok, yep, no probs
stop and look at container boat leaving for far off shores
then head back out, driving to the opposite side of building you booked in at, there are 2 gates here,
the one on the left for unit only, you just drive to the barrier and it opens automatically, you dont need to see anyone or hand anything in (this is where this photo is taken)
if you have picked a trailer up go to the right, so you drive down beside the main building, (but the opposite side to the one you came in) towards the green canopy, pull up at window and exchange your bit of paper for a gatepass
thru barrier and canopy
bear left back towards gate 2, straight over ■■■■■, to gatehouse
hand in gatepass after signing it, then off you go into the sunset
the good thing is, if its windy, and all the twistlock technicians have to park up till it stops, you can carry on, the weather doesnt ever close Norfolk Line, so if you see loads and loads of containers parked up, or the radio says Felixstowe is closed, it doesnt affect you.
