I have been driving a brand new MAN 440 Tipmatic (fleet spec) this week and I cannot believe how this passed QC and was allowed to be produced en masse. It is THE WORST auto box out there. The DAF auto was previously at the top of my âworstâ list for the light year it takes between gear changes, but that is now God-like in comparison to this heap of â â â â .
Thereâs a pic of the gear selector and stuff towards the end of this video if youâre not sure which box Iâm on about :
youtube.com/watch?v=Z-D3MRGZfMQ
The comments towards the end of the video are exactly the problem with it - the fleet spec version does not let you select any gear at all other than your âmoving offâ gear. As soon as you are rolling it goes back into auto and controls every gear change for you until you come to a stop again. Nice idea in theory but in practice it is absolutely HOPELESS.
It tries to pull away from all starts on whatever terrain in 3rd gear (of 12), but it block gears and goes to 5th then 7th, 8th and up. This is reasonably fine on the flat, but on even the slightest incline with a decent amount of weight on, 5th is just too high and with the 2 second pause between changes, youâve lost half your momentum as it changes up at 1400 revs and youâre down at 950 revs in 5th labouring the â â â â out of it so it dies and then has to change down to 4th. Meanwhile the traffic that was in front of you at the lights has now disappeared over the horizon and the lights are on red again.
And hills⌠it couldnât pull the skin off a rice pudding. Picture the scene: youâve come down to Brighouse from Harsthead Moor with 25 tonne on and are at the bottom of Ainley Bank. Itâs deceptively steep right where it splits into 4 lanes and you need to get a good run at it to stand any chance of going up the other side at ~40. Came down, in top (12th), stayed in top right until where it splits to 4 lanes, by this point the revs were off the bottom of the dial and it was already nearly down to 45. Changes down to 11th, now down to 40 and only just started to enter the righthand curve, but it changed down too low in the rev band, and now itâs too low in 11th and itâs labouring. Changes down to 10th and weâre down to 30mph. Got onto the straight bit where the incline eases slightly and it managed to pull itself to 32mph at 1400 revs and then changed up into 11th again, revs back down at 950 so too low for the blower to do anything, speed died AGAIN, back down in 10th and now 29mph. Seriously⌠IS THIS [ZB] FOR REAL?
After the first day with it I thought â â â â this â â â â and pulled out the user manual for it. There is nothing that I donât know about that truckâs operation now, but the only âusefulâ thing it tells you to stop it from changing down too early is to plant your loud foot and this activates kick down mode . Sounds impressive, but I knew that already from planting my foot to get the â â â â â â moving on the first day. Well I can tell you that it makes absolutely no noticeable difference whatsoever, as detailed above which was from day 2 and after reading the manual.
(I should point out just for clarification that the Tipmatic Profi spec allows you to manually select any gear you want, but not the fleet spec).
And the truck itself . Looks really smart from the outside with the colour coded mirrors and neon-style âstripâ lights for the side lights, but the interior is still â â â â â â with the fridge in the wrong place (RIGHT in front of the middle of the bunk, like a tower sticking out and totally preventing you from sitting on the bunk) and this new design has 18 foot of dashboard in front of you so unless you have the seat at maximum height so your legs are off the ground, you canât see the 5 cars in the queue directly in front of you. Imagine driving from the back seat of your car - well itâs akin to that. And the roll!!! FFS THE ROLL!!! Itâs like driving a bouncy castle, seriously. You could drive straight across 2ft ditches at the sides of the roads and wouldnât feel a thing, which sounds really nice, but the reality is that the cab is constantly swaying, rocking, bouncing about all over the place and corners like an oil tanker.
Pulling a loaded trailer with it is horrible - thereâs no feel to whatâs going on behind you as everything is ultra-damped and cushioned. It really lulls you into a false sense of security, or would do if the â â â â -box âgearboxâ would allow you to get to a speed where you could get a bit carried away.
HORRIBLE HORRIBLE TRUCK. Give me a Renault Premium any day over it
, even one with the factory standard rattling step. I will never complain about a Renault again after this. I even picked up an FH12 Idiot Shift from a hire place this afternoon and the difference between that and the MAN in terms of the gearboxes was like night and day. The I-Shift is far from perfect, but it just âworksâ and has all the functions for you to do your job with the ability to select your own gears.
/rant
