First, am I right in thinking you don’t need a tacho to use a 7.5T for private use , eg moving house or motor home etc,
Second, If you don’t need to use a tacho for private use is it still legal to drive for private use after driving one for commercial use for a full day … eg 9 hours driving.
In a nutshell, can I do a days work on tacho, then borrow a 7.5T to move house without using tacho?
The rules govern the carriage of goods for hire or reward.
If you are moving house for yourself, you have not hired the vehicle out and there is no reward.
You do not, therefore, need to follow the tachograph and O licensing rules.
If the 7.5 tonne gross vehicle is a motorhome, it is not a goods vehicle and also not a passenger carrying vehicle, so the rules do not apply to it either.
Common sense should prevent anyone from doing a full tachograph day or even a full day in the office and then another shift either moving house or taking the motorhome away on holiday.
Sadly, this is often not the case.
Squiddy:
YES … but I would suggest using the tacho in out of scope mode and doing a printout with explanation or by putting the reason on an analogue chart - just to cover any missing mileage
andy187:
have asked similar question as i occasionaly drive sisters horsebox and yes i have done 6days driving for work then drove box. not for hire or reward
As long as the horsebox or any LGV is not over 7.5 tonnes then that is ok for private use
