swivel
if only artics where this good in tight spaces
Nah!!
That would never work on an artic because tractor units have become much taller than in the past.
I think the present height of a modern tractor unit is probably due to the regulations regarding minimum cab heights and the distance that a driver needs to be from the steering wheel when on a rest break. :wink: :grimacing:
dieseldave:
Nah!!
That’s rubbish - you’ve got to be in the passenger seat if you are on break - I though everyone knew that :smiley:
Ah, Yes, But, if you disconnect the steering wheel and put it in the trailer then the police can’t touch you :sunglasses: .
(Look up drivers hours series four, page 8,425, paragraph 8, subsection C, amendment 75) :wink:
mushroomman:
Is that the same rule that state that you should be able to stand straight up while putting your boxers on■■? :unamused: :unamused:
And that the space beside the bed must have space for a kitchen roll if you do more than 5 nights out?? :unamused: :sunglasses:
(where can you wipe it else after a chocky?) :grimacing: :grimacing: :grimacing: :grimacing:
